Blank layout when using template
I have some problem when I use template to create a new layout.
If I design my template from the template tab, it’s impossible to ue it. Cause when I made a new layout with this one, I have a blank layout with only one full screen empty region. No design, no widget, no other region.
But if I create a layout then convert it in template. I could use this new one for new layout.
So why it doesn’t work ?
I created a template from the template page. But If I used it for a new layout, this last is blank. No region, no widget.
Hi welcome to the community!
Could you please confirm what version CMS you are using?
So I can understand the issue you are having, could you go through the steps you are taking to create your Layout as a Template? Have you ensured that the Layout has been Published and not in a draft status?
Thank you
