Automaticly Layouts switch
Hello
I try to switch the Layouts after 30 - 60 secondes
but on the Windows Clinet is only 1 Layout
Default Layout (Standard Layout immer mit anzeigen)
disable
You have 5 layouts in CMS, presumably the same 5 layouts are added to the campaign and presumably that campaign is scheduled to your windows player, correct?
Assuming that all 5 layouts are valid, we’d expect the player to cycle through all 5 of them in the order as specified in the campaign.
If that does not happen, please capture a screenshot of status window on the player ie
press ‘i’ on your keyboard while Xibo for Windows has focus to show the status window, then take a screenshot of it.
That should tell us what could potentially be wrong.
You can also check schedule.xml in the player local library to ensure that it has all 5 layouts listed there.
Could you also confirm for me the CMS and player version?
The Player is on Windows Version 1.8.8
I see now the version from CMS 1.8.9
is this the Problem?
Summary
LayoutId: 2. Runs from 01.01.1970 01:00:00
LayoutId: 1. Runs from 01.01.1970 01:00:00
LayoutId: 3. Runs from 01.01.1970 01:00:00
LayoutId: 5. Runs from 01.01.1970 01:00:00
LayoutId: 4. Runs from 01.01.1970 01:00:00
Overlay LayoutId: 2. Runs from 01.01.1970 01:00:00
Overlay LayoutId: 1. Runs from 01.01.1970 01:00:00
Overlay LayoutId: 3. Runs from 01.01.1970 01:00:00
Overlay LayoutId: 5. Runs from 01.01.1970 01:00:00
Overlay LayoutId: 4. Runs from 01.01.1970 01:00:00
media: compatibility.js. (100%)
media: pdf.js. (100%)
media: xibo-text-render.js. (100%)
media: 11.ttf. (100%)
media: 9.otf. (100%)
media: xibo-image-render.js. (100%)
media: xibo-layout-scaler.js. (100%)
media: moment.js. (100%)
media: xibo-webpage-render.js. (100%)
media: jquery-1.11.1.min.js. (100%)
media: pdf.worker.js. (100%)
media: jquery.marquee.min.js. (100%)
media: 12.otf. (100%)
media: 10.ttf. (100%)
media: 8.otf. (100%)
media: xibo-dataset-render.js. (100%)
media: flipclock.min.js. (100%)
media: fonts.css. (100%)
media: jquery-cycle-2.1.6.min.js. (100%)
media: 20.jpg. (100%)
media: 21.jpg. (100%)
layout: 1.xlf. (100%)
resource: 1.htm. (100%)
resource: 4.htm. (100%)
resource: 3.htm. (100%)
layout: 2.xlf. (100%)
resource: 5.htm. (100%)
resource: 7.htm. (100%)
resource: 9.htm. (100%)
layout: 3.xlf. (100%)
resource: 10.htm. (100%)
resource: 11.htm. (100%)
resource: 12.htm. (100%)
layout: 5.xlf. (100%)
resource: 16.htm. (100%)
resource: 17.htm. (100%)
resource: 18.htm. (100%)
layout: 4.xlf. (100%)
resource: 13.htm. (100%)
resource: 14.htm. (100%)
resource: 15.htm. (100%)
<?xml version="1.0"?> jquery-1.11.1.min.js jquery-cycle-2.1.6.min.js moment.js flipclock.min.js xibo-layout-scaler.js xibo-dataset-render.js xibo-image-render.js 8.otf 9.otf 10.ttf 11.ttf 12.otf xibo-text-render.js jquery.marquee.min.js pdf.js pdf.worker.js compatibility.js xibo-webpage-render.js fonts.css
It seems to me like you have your campaign with layouts 1, 2, 3 ,4 5 scheduled with always daypart multiple times to this player - it would be best to have that as one event.
Then you have all 5 layouts scheduled as overlay layouts also with always daypart, I’m not quite sure why to be honest, assuming all layouts are full screen, then I don’t think you want to have them scheduled as normal and overlay layouts?
I’d guess one event scheduled with always as “normal” layouts is all you need.
You also seem to have XMR not configured correctly, if that’s a manual installation on a web server, then please see - https://xibo.org.uk/manual/en/install_xmr.html
If XTR (tasks) is also not configured, then it is crucial to get that working https://xibo.org.uk/manual/en/install_xtr.html
