Audio playback not working?
Anybody else having audio issue with 4.0.13? been playing with settings all day trying to get it working no dice. Ubuntu 26.04.1 LTS
Does arexibo works in the same setup ? Release v0.6.9 · romoloman/arexibo · GitHub
I didn’t tested with audio file directly but i was able to make 4.0.13 work with audio from mp4 videos.
After way to much experimenting YouTube videos work. Local audio and video files have no audio. Mp3 and mp4
I have passed over to the team for a closer look.
Thank you
I believe audio is disabled system wide by default. So files that play using the embedded media engine by default are muted.
Thanks for testing this. Picking up from where Natasha passed it over, there are two causes:
MP4 / Video widgets. New Video widgets are muted by default. The CMS setting for this is Administration → Modules → Video → Default Mute?, and it’s on out of the box. Open the widget, untick Mute?, and publish the layout. If you want new video widgets to have sound from now on, you can also turn the module default off. As Jon mentioned, YouTube works because it’s an embedded web page, so this setting doesn’t apply to it.
MP3 / Audio widgets. This one is a bug in the player. The Audio widget is created without a source URL, so nothing plays and nothing is logged. It’s tracked in #266, and the fix will be in the next player release.
