Audio is not working
I am trying play audio but it is not playing. It is working fine with video.
What CMS version and player versions are you using please?
Have you added Audio widget or did you add an audio to other existing widget?
I am using xibo cms 1.8.9 and i am current testing it in preview layout mode, yes i added audio widget.
I’d suggest scheduling the layout to the player and see if it works there.
Thanks for your help…
