2.3.10 docker and 2.3.10 develope
I’m trying to Assign display to dispalygroup with API but doesn’t works: the display isn’t assigned. I’m using postman, the url is /displaygroup/:displayGroupId/display/assign, I tried different version of displayid array (i.e. [“id1”,“id2”] or [id1,id2] or id1,id2) but no one works.
Checking the code I saw that the sanitizer getIntArray function return every time an empty value (controller DisplayGroup.php function assignDisplay line 733 approx “$displays = $this->getSanitizer()->getIntArray(‘displayId’);”).
The cms use the same controller but posting value in different mode.
Could you help me.
Ender
