Arrêt/démarrage Ecran avec DSCS9
Bonjour,
Désolé si j’ouvre un sujet déjà existant, mais je ne trouve pas de solutions à mon problème.
Je suis sur un CMS 3.0, j’ai un boitier DSCS9.
La commande arrêt fonctionne, mais pas la démarrage.
J’ai testé sur DSCS DEVICES et cela fonctionne.
Ci-joint, copie d’écran des commandes que j’ai déclarée
Hi Herve, than you for your message. You mentioned you are using CMS version 3, could you install the latest v3 player onto your DSCS9 and try the following commands.
You can download R302 here.
Screen Off command: dsd_cec_off
Screen On command: dsd_cec_on
You will also need to make sure that XMR is working when sending commands. Alternatively, you can also schedule the commands to run, which does not require XMR but you will need to ensure that the player has had enough time to connect to your CMS and download the command event before it is due to run.
