Can I use ARM server to run CMS?
I don’t believe we publish arm Docker containers, but you should be able to build containers using our docker files directly.
Failing that, you can do a custom install assuming your base OS provides the necessary libraries compiled for arm.
OK I can stick with Intel. Thanks for your help @Alex
@alex Any news about the 2.0 version? I just wonder it’s a right time to start building with 2.0 or 1.8. I don’t have any clients yet so it might take some time to get things up and running.
2.0 is still in beta. We don’t recommend it for production use, and there are no Players available for it yet.
If you’re building a production system, then you should be using 1.8 until we hit 2.0.0 stable - at which point you may consider upgrading.
