API OverlayLayout does not show
I succesfully managed to use changeLayout API
https://xibo.org.uk/manual-tempel/api/#/displayGroup/displayGroupActionChangeLayout
and layout changes on the display.
When I try overlayLayout
https://xibo.org.uk/manual-tempel/api/#/displayGroup/displayGroupActionOverlayLayout
I get success
“grid”: false,
“success”: true,
“status”: 204,
“message”: “Command Sent to TestApi0001”,
“id”: 33,
“data”: []
but display content does not change as it does with changeLayout.
What is wrong?
Hi there,
Which Player are you using please?
Android, v2 R205. I’ll give it a try with Windows player.
Aaah, no luck. Win 7 x64. Have to find some other machine …
