Hi Dan,
What happens with the licenses for the android player if Spring Signage stops supporting Xibo ?
That would mean that all the android players would stop running. Is there a fallback plan in that case ?
Ralph
Hi Dan,
Ralph
Provision has been made to release a version without licence checking in that event. You will not loose access to the software.
Thanks Alex for the swift and clear answer
