Android Connecting to CMS does not create new display
I am setting up a couple of new Minix Neo z64 devices. I connected the first device to my local CMS and it worked as expected. When I set up the second one a new device was not created in the CMS. It simply over wrote the one I had set up earlier and held the same Display ID. The IP address changed as well as the MAC address. Found something through a google search that said I should do a Clear Data on the Xibo player on both devices and start over. This did not solve the problem. Can anyone help with this…?
Thanks in advance.
Problem solved! For some reason the two brand new Neo z64s generated the same machine key. I modified the key under settings on the player and it generated a new device ID.
