Android Client: Unable to choose SD Card for storage
I’m using the Xibo Android client (latest build) and I’ve chosen the option Public Storage. When I click on Storage Location, it displays only the internal storage. SD card is viewable through other apps. Android version is 5.1.1.
How do I fix this?
Thanks,
Sourjya
Public storage and first option under storage options should be fine - it will cause your device to download everything again to new storage location (sd card in this case)
Thanks Peter. Is there a way to check? Can I eject the SD card and look for the files there? What folder should they be present under.
Thanks,
Sourjya
you can check with file explorer on your device
so it will be on local storage/sd card in
/data/data/uk.org.xibo.client/
Thank you very much, Peter.
