Anyone tried Xibo client on RemixOS?
http://www.jide.com/en/remixos
It’s very nice that they have the Remix Mini as a standalone device like any know TV-box, but they also have an ISO build to run on standard X86 PCs. Both 32 and 64 bit!
I just bought a Remix Mini little box, and Xibo works perfectly with it.
http://www.jide.com/en/mini
The best about it, it’s not filled with tons of bloatware you have to remove. It’s just plain simple Android 5.1 with a PC-Desktop-style launcher (can be used pretty well with a standard keyboard and mouse).
Xibo installed from APK file works straight out of the box.
Really considerable to be deployed on tens of locations.
Starts up immediately as power is applied, so no problem with power outages either.
Audio comes out through HDMI and the headphone jack also (can be set).
Not getting hot, just a bit warm. Perfectly acceptable.
That’s good to hear, I don’t think we had a opportunity to test it, but perhaps we should give it a shot if it’s really reliable solution, I think that the price for the box it’s quite fine too.
