Hi I made a topic about this a short while ago but I had to focus on other things so it fell off my radar. We have an android client that keeps crashing, we have 2 of the same machines running the client and only one of them crashes. The Xibo version is v59 and the android version is 5.1. Its one of these:
https://www.amazon.co.uk/dp/B01H6ORG6I/ref=pe_385721_37986871_TE_item
I tried at first to get error logs to send to our CMS which they won’t for some reason. I can get error logs to appear from our other display screen but not this one. So I used catlog and was left with these error messages after a crash.
“invalid address or address of corrupt block 0xb895a698 passed to dlfree”
“Fatal Signal 11 (SIGSEGV), code 1, fault addr 0xdeadbaad in tid 2593 (Binder_3)”
“heap corruption detected by dlfree”
“Fatal signal 6 (SIGABRT), code -6 in tid 2653 (Binder_3)”
This was after it crashed yesterday, when I came to it today I pressed to force close Xibo from the crash message and it restarted the machine. I think it is likely the android box is faulty but if you have any ideas it would be appreciated.
it also seems to endlessly repeat this message for a while after a crash occurs:
“EventThread: dropping event (7673796e) for connection 0xb89d4640”
