I’ve got some troubles with transitions.
The first one is the South Transition.
It’s been consistent with multiples android box and Layouts.
When I put a Region with a Fly Transition and a South Orientation, at the beginning of the presentation there is a flash where you can see the region for a very short amount of time at the center. Then it does the transition correctly.
I can give you a presentation, but it’s easy to reproduce :
Create a region
Put an image inside
Change the transition to “Fly” and “South”
I think there is a problem only with the south transition, but I haven’t try the South-east …
It would seem that when there is only one item in the region with transitions, the exit transition is not displayed ie it shows in transition and then reload the layout.
If you have two items in the region, both with in/out transitions then it does show in and out transitions for both items.
I’ve logged an issue in github to take a look at it, thank you for bringing this to our attention
You can clearly see that each time the south transition is triggered (For Fly IN), there is a flash with the picture. But you can see that the North Transition is working good. This issue is still here when I put a second image inside the region (two images with Fly In South, Fly Out North)
I’m using a French CMS and Android.
I’m sorry if it’s complicated to understand what I’m trying to say
Ask anything if I’m not clear enough.
If you don’t have troubles with this one, I will check my CMS (maybe the updates broke somethings). But this is a real problem for us, because we are using this kind of transition A LOT.
