Thanks for your help in advance.
I have setup the server everything is running normal. I have connected an android box with two 55 inch tvs through a hdmi splitter.
I want to make one big display by combing both TVs. Is that possible if yes, please let me know how it is possible. At the moment the android box is showing same display on both TVs.
thank you
An HDMI splitter will send the same image to both TVs. It’s not possible to make a video wall in that way.
There are devices that are designed to take a single HDMI output from your Android device and turn that in to separate images for making video walls from. I can’t recommend a specific unit to you however.
Thank you for the reply alex. If you do remember the name of it. Please let me know so i can buy.
