Android APP with connection speed setting
For some users with limitations on connectivity, we could be at the APP configuration transfer rate which the equipment can work.
We could have Kbps selectable options.
This would complement the functionality of the update window and upgrade window.
I believe it is a differential for network managers and infrastructure.
