Alteranate 2 dataset entries
there is a way most likely a way, but how can I use a data set for every week it alternates them
for example week 1 and week 2 how could I alternate them weekly
You could have a column with list content (or string, that would work too), with values week1 and week2, then set the filter for your ticker/datasetView with that column set to either week1 or week2.
^ that’s assuming everything is one dataSet.
If you have two separate dataSets, then you’d most likely need 2 separate layouts and then manage the scheduled event to show the relevant layout.
it is one dataset with two entries so all I need to find is a filter to alternate this each week,
thank you
if you have one that would be great
