#ASK #HELP
how can i solves this issue?
i’m using UBUNTU 16.04 as server and xibo 2.1.0 with docker
Xibo sets the permissions on the library when the container starts itself, so it suggests you’ve manually changed the permissions on the library directory after starting the containers.
If you down/up the containers, it will fix the permissions for you.
can you explain further by example up/down the containers?
what should i write in the terminal?
Assuming you used the standard docker-compose files:
docker-compose down
docker-compose up -d
If you used remote MySQL or custom ports, then you’d need to name that file in the command - for example
docker-compose -f cms_custom-ports.yml down
docker-compose -f cms_custom-ports.yml up -d
Check your docker log to see what it’s saying the problem is.
sorry, how i check the docker log?
docker-compose ps
docker-compose logs
thanks sir, i’ll try now
*** ***docker-compose ps*** ***
docker-compose logs
Attaching to xibo_cms-web_1, xibo_cms-db_1, xibo_cms-xmr_1 cms-web_1 | Waiting for MySQL to start - max 300 seconds cms-web_1 | MySQL started cms-web_1 | Updating settings.php cms-web_1 | settingId cms-web_1 | 1 cms-web_1 | Existing Database, checking if we need to upgrade it cms-web_1 | Phinx by CakePHP - https://phinx.org. 0.9.2 cms-web_1 | cms-web_1 | using config file .varwwwcmsphinx.php cms-web_1 | using config parser php cms-web_1 | using migration paths cms-web_1 | - /var/www/cms/db/migrations cms-web_1 | warning no environment specified, defaulting to: production cms-web_1 | ordering by creation time cms-web_1 | cms-web_1 | Status [Migration ID] Started Finished Migration Name cms-web_1 | ---------------------------------------------------------------------------------- cms-web_1 | up 20180130073838 2020-01-23 09:10:09 2020-01-23 09:10:56 InstallMigration cms-web_1 | up 20180131113100 2020-01-23 09:10:56 2020-01-23 09:10:56 OldUpgradeStep85Migration cms-web_1 | up 20180131113853 2020-01-23 09:10:57 2020-01-23 09:10:57 OldUpgradeStep86Migration cms-web_1 | up 20180131113941 2020-01-23 09:10:57 2020-01-23 09:10:57 OldUpgradeStep87Migration cms-web_1 | up 20180131113948 2020-01-23 09:10:57 2020-01-23 09:10:57 OldUpgradeStep88Migration cms-web_1 | up 20180131113952 2020-01-23 09:10:57 2020-01-23 09:10:57 OldUpgradeStep92Migration cms-web_1 | up 20180131113957 2020-01-23 09:10:57 2020-01-23 09:10:57 OldUpgradeStep120Migration cms-web_1 | up 20180131114002 2020-01-23 09:10:57 2020-01-23 09:10:57 OldUpgradeStep121Migration cms-web_1 | up 20180131114007 2020-01-23 09:10:57 2020-01-23 09:10:57 OldUpgradeStep122Migration cms-web_1 | up 20180131114013 2020-01-23 09:10:57 2020-01-23 09:10:57 OldUpgradeStep123Migration cms-web_1 | up 20180131114017 2020-01-23 09:10:57 2020-01-23 09:10:57 OldUpgradeStep124Migration cms-web_1 | up 20180131114021 2020-01-23 09:10:57 2020-01-23 09:10:57 OldUpgradeStep125Migration cms-web_1 | up 20180131114025 2020-01-23 09:10:57 2020-01-23 09:10:57 OldUpgradeStep126Migration cms-web_1 | up 20180131114030 2020-01-23 09:10:57 2020-01-23 09:10:57 OldUpgradeStep127Migration cms-web_1 | up 20180131114050 2020-01-23 09:10:57 2020-01-23 09:10:57 OldUpgradeStep128Migration cms-web_1 | up 20180131114058 2020-01-23 09:10:57 2020-01-23 09:10:57 OldUpgradeStep129Migration cms-web_1 | up 20180131114103 2020-01-23 09:10:58 2020-01-23 09:10:58 OldUpgradeStep130Migration cms-web_1 | up 20180131114107 2020-01-23 09:10:58 2020-01-23 09:10:58 OldUpgradeStep131Migration cms-web_1 | up 20180131114110 2020-01-23 09:10:58 2020-01-23 09:10:58 OldUpgradeStep132Migration cms-web_1 | up 20180131114114 2020-01-23 09:10:58 2020-01-23 09:10:58 OldUpgradeStep133Migration cms-web_1 | up 20180131114118 2020-01-23 09:10:58 2020-01-23 09:10:58 OldUpgradeStep134Migration cms-web_1 | up 20180131114123 2020-01-23 09:10:58 2020-01-23 09:10:58 OldUpgradeStep135Migration cms-web_1 | up 20180131122645 2020-01-23 09:10:58 2020-01-23 09:11:05 OneRegionPerPlaylistMigration cms-web_1 | up 20180131123038 2020-01-23 09:11:06 2020-01-23 09:11:06 PlaylistTagsMigration cms-web_1 | up 20180131123248 2020-01-23 09:11:06 2020-01-23 09:11:08 WidgetFromToDtMigration cms-web_1 | up 20180212143336 2020-01-23 09:11:08 2020-01-23 09:11:09 DaypartSystemEntriesAsRecords cms-web_1 | up 20180213173846 2020-01-23 09:11:09 2020-01-23 09:11:09 MailFromNameSettingMigration cms-web_1 | up 20180219141257 2020-01-23 09:11:09 2020-01-23 09:11:11 DisplayGroupClosureIndexToNonUnique cms-web_1 | up 20180223180534 2020-01-23 09:11:11 2020-01-23 09:11:13 DataSetColumnFilterAndSortOptionsMigration cms-web_1 | up 20180302182421 2020-01-23 09:11:13 2020-01-23 09:11:14 WidgetCreatedAndModifiedDtMigration cms-web_1 | up 20180313085749 2020-01-23 09:11:14 2020-01-23 09:11:15 MediaTableEditedIdIndexMigration cms-web_1 | up 20180320154652 2020-01-23 09:11:15 2020-01-23 09:11:17 PlaylistAddDynamicFilterMigration cms-web_1 | up 20180327153325 2020-01-23 09:11:17 2020-01-23 09:11:17 RemoveUserLoggedInMigration cms-web_1 | up 20180514114415 2020-01-23 09:11:18 2020-01-23 09:11:18 FixCaseOnHelpTextFieldMigration cms-web_1 | up 20180515123835 2020-01-23 09:11:18 2020-01-23 09:11:21 LayoutPublishDraftMigration cms-web_1 | up 20180529065816 2020-01-23 09:11:21 2020-01-23 09:11:22 DataSetTruncateFixMigration cms-web_1 | up 20180529073531 2020-01-23 09:11:22 2020-01-23 09:11:23 DisplayAsVncLinkMigration cms-web_1 | up 20180621134013 2020-01-23 09:11:23 2020-01-23 09:11:23 AddWidgetSyncTaskMigration cms-web_1 | up 20180621134250 2020-01-23 09:11:23 2020-01-23 09:11:23 EventLayoutPermissionSettingMigration cms-web_1 | up 20180906115552 2020-01-23 09:11:23 2020-01-23 09:11:23 AddForeignKeysToTagsMigration cms-web_1 | up 20180906115606 2020-01-23 09:11:23 2020-01-23 09:11:26 AddForeignKeysToPermissionsMigration cms-web_1 | up 20180906115712 2020-01-23 09:11:26 2020-01-23 09:11:26 AddForeignKeysToWidgetMediaMigration cms-web_1 | up 20180906131643 2020-01-23 09:11:26 2020-01-23 09:11:27 ForgottenPasswordReminderMigration cms-web_1 | up 20180906131716 2020-01-23 09:11:27 2020-01-23 09:11:28 DataSetRssMigration cms-web_1 | up 20181011160130 2020-01-23 09:11:28 2020-01-23 09:11:35 SimpleSettingsMigration cms-web_1 | up 20181113173310 2020-01-23 09:11:35 2020-01-23 09:11:35 RemoveFinanceModuleMigration cms-web_1 | up 20181113180337 2020-01-23 09:11:36 2020-01-23 09:11:36 SplitTickerModuleMigration cms-web_1 | up 20181126113231 2020-01-23 09:11:36 2020-01-23 09:11:36 Release1812Migration cms-web_1 | up 20181210092443 2020-01-23 09:11:36 2020-01-23 09:11:37 RemoveImageUriModuleMigration cms-web_1 | up 20181212114400 2020-01-23 09:11:37 2020-01-23 09:11:37 CreatePlayerVersionsTableMigration cms-web_1 | up 20181217135044 2020-01-23 09:11:37 2020-01-23 09:11:38 EventSyncMigration cms-web_1 | up 20190121092556 2020-01-23 09:11:38 2020-01-23 09:11:40 PlayerUpgradeAndOverrideConfigMigration cms-web_1 | up 20190125170130 2020-01-23 09:11:40 2020-01-23 09:11:41 PlayerSoftwareVersionFieldMigration cms-web_1 | up 20190129103831 2020-01-23 09:11:41 2020-01-23 09:11:41 AddLinuxDisplayProfileMigration cms-web_1 | up 20190212112534 2020-01-23 09:11:41 2020-01-23 09:11:41 AddProofOfPlayStatsDurationAndCountMigration cms-web_1 | up 20190212115432 2020-01-23 09:11:41 2020-01-23 09:11:41 AddDefaultTransitionDurationSettingMigration cms-web_1 | up 20190213160914 2020-01-23 09:11:41 2020-01-23 09:11:41 AddGlobalStatSettingMigration cms-web_1 | up 20190213162212 2020-01-23 09:11:41 2020-01-23 09:11:41 AddHorizontalMenuSettingMigration cms-web_1 | up 20190214102508 2020-01-23 09:11:41 2020-01-23 09:11:42 AddLayoutEnableStat cms-web_1 | up 20190214102516 2020-01-23 09:11:42 2020-01-23 09:11:43 AddMediaEnableStat cms-web_1 | up 20190220165703 2020-01-23 09:11:43 2020-01-23 09:11:44 AddScheduleRecurrenceMonthlyRepeatsOnMigration cms-web_1 | up 20190227101705 2020-01-23 09:11:44 2020-01-23 09:11:44 MakeDisplayLicenseColumnUniqueMigration cms-web_1 | up 20190228120603 2020-01-23 09:11:44 2020-01-23 09:11:45 AddDynamicCriteriaTagsMigration cms-web_1 | up 20190301115046 2020-01-23 09:11:45 2020-01-23 09:11:45 AdjustGenericfileValidExtensionsMigration cms-web_1 | up 20190315134628 2020-01-23 09:11:45 2020-01-23 09:11:46 AddBandwidthLimitColumnToDisplaygroupMigration cms-web_1 | up 20190322162052 2020-01-23 09:11:46 2020-01-23 09:11:47 AddPublishedDateColumnMigration cms-web_1 | up 20190326163016 2020-01-23 09:11:47 2020-01-23 09:11:47 CreateLayoutHistoryTableMigration cms-web_1 | up 20190328111718 2020-01-23 09:11:47 2020-01-23 09:11:47 AddCampaignStatMigration cms-web_1 | up 20190401150256 2020-01-23 09:11:48 2020-01-23 09:11:48 AddScheduleNowPageMigration cms-web_1 | up 20190509101525 2020-01-23 09:11:48 2020-01-23 09:11:48 CreateReportScheduleTableMigration cms-web_1 | up 20190509102648 2020-01-23 09:11:48 2020-01-23 09:11:49 CreateSavedReportTableMigration cms-web_1 | up 20190509113001 2020-01-23 09:11:49 2020-01-23 09:11:49 AddReportPageMigration cms-web_1 | up 20190510140126 2020-01-23 09:11:49 2020-01-23 09:11:51 TwoFactorAuthMigration cms-web_1 | up 20190514134430 2020-01-23 09:11:51 2020-01-23 09:11:53 NullableTextFieldsMigration cms-web_1 | up 20190515094133 2020-01-23 09:11:54 2020-01-23 09:11:54 AddHtmlDatatypeMigration cms-web_1 | up 20190515105624 2020-01-23 09:11:54 2020-01-23 09:11:54 InstallAdditionalStandardModulesMigration cms-web_1 | up 20190517080033 2020-01-23 09:11:54 2020-01-23 09:11:56 AddForeignKeysToLktagTablesMigration cms-web_1 | up 20190521092700 2020-01-23 09:11:56 2020-01-23 09:11:56 AddReportScheduleTaskMigration cms-web_1 | up 20190521092930 2020-01-23 09:11:56 2020-01-23 09:11:57 AddPreviousRunDateReportScheduleMigration cms-web_1 | up 20190521102635 2020-01-23 09:11:57 2020-01-23 09:11:58 PlaylistDurationUpdateAtTimestamp cms-web_1 | up 20190603083836 2020-01-23 09:11:58 2020-01-23 09:11:59 ChangeStatTableStartEndColumnMigration cms-web_1 | up 20190610150331 2020-01-23 09:15:05 2020-01-23 09:15:06 TagsWithValuesMigration cms-web_1 | up 20190611145607 2020-01-23 09:15:06 2020-01-23 09:15:06 RemoveOldVersionTableMigration cms-web_1 | up 20190612140955 2020-01-23 09:15:06 2020-01-23 09:15:10 DisplayTableDatabaseSchemaAdjustmentsMigration cms-web_1 | up 20190620112611 2020-01-23 09:15:10 2020-01-23 09:15:11 MoveTidyStatsToStatsArchiveTaskMigration cms-web_1 | up 20190620142655 2020-01-23 09:15:11 2020-01-23 09:15:12 AddPlaylistEnableStatMigration cms-web_1 | up 20190626091331 2020-01-23 09:15:12 2020-01-23 09:15:13 WidgetHistoryMigration cms-web_1 | up 20190626110359 2020-01-23 09:15:13 2020-01-23 09:15:16 CreateStatTableMigration cms-web_1 | up 20190628083649 2020-01-23 09:15:16 2020-01-23 09:15:16 AddStatsMigrationTaskMigration cms-web_1 | up 20190710213414 2020-01-23 09:15:16 2020-01-23 09:15:21 AddIsActiveReportScheduleMigration cms-web_1 | up 20190717101342 2020-01-23 09:15:21 2020-01-23 09:15:21 NullableCommandValidationStringMigration cms-web_1 | up 20190719074601 2020-01-23 09:15:22 2020-01-23 09:15:22 MissingDefaultValueMigration cms-web_1 | up 20190801102042 2020-01-23 09:15:22 2020-01-23 09:15:22 DisplayProfileCommandLinkFixMigration cms-web_1 | cms-web_1 | Importing ca-certs cms-web_1 | cp: can't stat '/var/www/cms/ca-certs/*.pem': No such file or directory cms-web_1 | cp: can't stat '/var/www/cms/ca-certs/*.crt': No such file or directory cms-web_1 | WARNING: ca-certificates.crt does not contain exactly one certificate or CRL: skipping cms-web_1 | Configuring Maintenance cms-web_1 | Waiting for MySQL to start - max 300 seconds cms-web_1 | MySQL started cms-web_1 | settingId cms-web_1 | 1 cms-web_1 | Existing Database, checking if we need to upgrade it cms-web_1 | Phinx by CakePHP - https://phinx.org. 0.9.2 cms-web_1 | cms-web_1 | using config file .varwwwcmsphinx.php cms-web_1 | using config parser php cms-web_1 | using migration paths cms-web_1 | - /var/www/cms/db/migrations cms-web_1 | warning no environment specified, defaulting to: production cms-web_1 | ordering by creation time cms-web_1 | cms-web_1 | Status [Migration ID] Started Finished Migration Name cms-web_1 | ---------------------------------------------------------------------------------- cms-web_1 | up 20180130073838 2020-01-23 09:10:09 2020-01-23 09:10:56 InstallMigration cms-web_1 | up 20180131113100 2020-01-23 09:10:56 2020-01-23 09:10:56 OldUpgradeStep85Migration cms-web_1 | up 20180131113853 2020-01-23 09:10:57 2020-01-23 09:10:57 OldUpgradeStep86Migration cms-web_1 | up 20180131113941 2020-01-23 09:10:57 2020-01-23 09:10:57 OldUpgradeStep87Migration cms-web_1 | up 20180131113948 2020-01-23 09:10:57 2020-01-23 09:10:57 OldUpgradeStep88Migration cms-web_1 | up 20180131113952 2020-01-23 09:10:57 2020-01-23 09:10:57 OldUpgradeStep92Migration cms-web_1 | up 20180131113957 2020-01-23 09:10:57 2020-01-23 09:10:57 OldUpgradeStep120Migration cms-web_1 | up 20180131114002 2020-01-23 09:10:57 2020-01-23 09:10:57 OldUpgradeStep121Migration cms-web_1 | up 20180131114007 2020-01-23 09:10:57 2020-01-23 09:10:57 OldUpgradeStep122Migration cms-web_1 | up 20180131114013 2020-01-23 09:10:57 2020-01-23 09:10:57 OldUpgradeStep123Migration cms-web_1 | up 20180131114017 2020-01-23 09:10:57 2020-01-23 09:10:57 OldUpgradeStep124Migration cms-web_1 | up 20180131114021 2020-01-23 09:10:57 2020-01-23 09:10:57 OldUpgradeStep125Migration cms-web_1 | up 20180131114025 2020-01-23 09:10:57 2020-01-23 09:10:57 OldUpgradeStep126Migration cms-web_1 | up 20180131114030 2020-01-23 09:10:57 2020-01-23 09:10:57 OldUpgradeStep127Migration cms-web_1 | up 20180131114050 2020-01-23 09:10:57 2020-01-23 09:10:57 OldUpgradeStep128Migration cms-web_1 | up 20180131114058 2020-01-23 09:10:57 2020-01-23 09:10:57 OldUpgradeStep129Migration cms-web_1 | up 20180131114103 2020-01-23 09:10:58 2020-01-23 09:10:58 OldUpgradeStep130Migration cms-web_1 | up 20180131114107 2020-01-23 09:10:58 2020-01-23 09:10:58 OldUpgradeStep131Migration cms-web_1 | up 20180131114110 2020-01-23 09:10:58 2020-01-23 09:10:58 OldUpgradeStep132Migration cms-web_1 | up 20180131114114 2020-01-23 09:10:58 2020-01-23 09:10:58 OldUpgradeStep133Migration cms-web_1 | up 20180131114118 2020-01-23 09:10:58 2020-01-23 09:10:58 OldUpgradeStep134Migration cms-web_1 | up 20180131114123 2020-01-23 09:10:58 2020-01-23 09:10:58 OldUpgradeStep135Migration cms-web_1 | up 20180131122645 2020-01-23 09:10:58 2020-01-23 09:11:05 OneRegionPerPlaylistMigration cms-web_1 | up 20180131123038 2020-01-23 09:11:06 2020-01-23 09:11:06 PlaylistTagsMigration cms-web_1 | up 20180131123248 2020-01-23 09:11:06 2020-01-23 09:11:08 WidgetFromToDtMigration cms-web_1 | up 20180212143336 2020-01-23 09:11:08 2020-01-23 09:11:09 DaypartSystemEntriesAsRecords cms-db_1 | 2020-01-23 09:35:36+00:00 [Note] [Entrypoint]: Entrypoint script for MySQL Server 5.6.47-1debian9 started. cms-db_1 | 2020-01-23 09:35:40+00:00 [Note] [Entrypoint]: Switching to dedicated user 'mysql' cms-db_1 | 2020-01-23 09:35:41+00:00 [Note] [Entrypoint]: Entrypoint script for MySQL Server 5.6.47-1debian9 started. cms-db_1 | 2020-01-23 09:35:41 0 [Warning] TIMESTAMP with implicit DEFAULT value is deprecated. Please use --explicit_defaults_for_timestamp server option (see documentation for more details). cms-db_1 | 2020-01-23 09:35:41 0 [Note] mysqld (mysqld 5.6.47) starting as process 1 ... cms-db_1 | 2020-01-23 09:35:41 1 [Note] Plugin 'FEDERATED' is disabled. cms-db_1 | 2020-01-23 09:35:41 1 [Note] InnoDB: Using atomics to ref count buffer pool pages cms-db_1 | 2020-01-23 09:35:41 1 [Note] InnoDB: The InnoDB memory heap is disabled cms-db_1 | 2020-01-23 09:35:41 1 [Note] InnoDB: Mutexes and rw_locks use GCC atomic builtins cms-db_1 | 2020-01-23 09:35:41 1 [Note] InnoDB: Memory barrier is not used cms-db_1 | 2020-01-23 09:35:41 1 [Note] InnoDB: Compressed tables use zlib 1.2.11 cms-db_1 | 2020-01-23 09:35:41 1 [Note] InnoDB: Using Linux native AIO cms-db_1 | 2020-01-23 09:35:41 1 [Note] InnoDB: Not using CPU crc32 instructions cms-db_1 | 2020-01-23 09:35:41 1 [Note] InnoDB: Initializing buffer pool, size = 128.0M cms-db_1 | 2020-01-23 09:35:42 1 [Note] InnoDB: Completed initialization of buffer pool cms-db_1 | 2020-01-23 09:35:42 1 [Note] InnoDB: Highest supported file format is Barracuda. cms-db_1 | 2020-01-23 09:35:43 1 [Note] InnoDB: 128 rollback segment(s) are active. cms-db_1 | 2020-01-23 09:35:43 1 [Note] InnoDB: Waiting for purge to start cms-web_1 | up 20180213173846 2020-01-23 09:11:09 2020-01-23 09:11:09 MailFromNameSettingMigration cms-web_1 | up 20180219141257 2020-01-23 09:11:09 2020-01-23 09:11:11 DisplayGroupClosureIndexToNonUnique cms-web_1 | up 20180223180534 2020-01-23 09:11:11 2020-01-23 09:11:13 DataSetColumnFilterAndSortOptionsMigration cms-web_1 | up 20180302182421 2020-01-23 09:11:13 2020-01-23 09:11:14 WidgetCreatedAndModifiedDtMigration cms-web_1 | up 20180313085749 2020-01-23 09:11:14 2020-01-23 09:11:15 MediaTableEditedIdIndexMigration cms-web_1 | up 20180320154652 2020-01-23 09:11:15 2020-01-23 09:11:17 PlaylistAddDynamicFilterMigration cms-web_1 | up 20180327153325 2020-01-23 09:11:17 2020-01-23 09:11:17 RemoveUserLoggedInMigration cms-web_1 | up 20180514114415 2020-01-23 09:11:18 2020-01-23 09:11:18 FixCaseOnHelpTextFieldMigration cms-web_1 | up 20180515123835 2020-01-23 09:11:18 2020-01-23 09:11:21 LayoutPublishDraftMigration cms-web_1 | up 20180529065816 2020-01-23 09:11:21 2020-01-23 09:11:22 DataSetTruncateFixMigration cms-web_1 | up 20180529073531 2020-01-23 09:11:22 2020-01-23 09:11:23 DisplayAsVncLinkMigration cms-web_1 | up 20180621134013 2020-01-23 09:11:23 2020-01-23 09:11:23 AddWidgetSyncTaskMigration cms-db_1 | 2020-01-23 09:35:43 1 [Note] InnoDB: 5.6.47 started; log sequence number 3986790 cms-db_1 | 2020-01-23 09:35:43 1 [Note] RSA private key file not found: /var/lib/mysql//private_key.pem. Some authentication plugins will not work. cms-db_1 | 2020-01-23 09:35:43 1 [Note] RSA public key file not found: /var/lib/mysql//public_key.pem. Some authentication plugins will not work. cms-db_1 | 2020-01-23 09:35:43 1 [Note] Server hostname (bind-address): '*'; port: 3306 cms-web_1 | up 20180621134250 2020-01-23 09:11:23 2020-01-23 09:11:23 EventLayoutPermissionSettingMigration cms-web_1 | up 20180906115552 2020-01-23 09:11:23 2020-01-23 09:11:23 AddForeignKeysToTagsMigration cms-web_1 | up 20180906115606 2020-01-23 09:11:23 2020-01-23 09:11:26 AddForeignKeysToPermissionsMigration cms-web_1 | up 20180906115712 2020-01-23 09:11:26 2020-01-23 09:11:26 AddForeignKeysToWidgetMediaMigration cms-web_1 | up 20180906131643 2020-01-23 09:11:26 2020-01-23 09:11:27 ForgottenPasswordReminderMigration cms-web_1 | up 20180906131716 2020-01-23 09:11:27 2020-01-23 09:11:28 DataSetRssMigration cms-web_1 | up 20181011160130 2020-01-23 09:11:28 2020-01-23 09:11:35 SimpleSettingsMigration cms-web_1 | up 20181113173310 2020-01-23 09:11:35 2020-01-23 09:11:35 RemoveFinanceModuleMigration cms-web_1 | up 20181113180337 2020-01-23 09:11:36 2020-01-23 09:11:36 SplitTickerModuleMigration cms-web_1 | up 20181126113231 2020-01-23 09:11:36 2020-01-23 09:11:36 Release1812Migration cms-web_1 | up 20181210092443 2020-01-23 09:11:36 2020-01-23 09:11:37 RemoveImageUriModuleMigration cms-web_1 | up 20181212114400 2020-01-23 09:11:37 2020-01-23 09:11:37 CreatePlayerVersionsTableMigration cms-web_1 | up 20181217135044 2020-01-23 09:11:37 2020-01-23 09:11:38 EventSyncMigration cms-web_1 | up 20190121092556 2020-01-23 09:11:38 2020-01-23 09:11:40 PlayerUpgradeAndOverrideConfigMigration cms-web_1 | up 20190125170130 2020-01-23 09:11:40 2020-01-23 09:11:41 PlayerSoftwareVersionFieldMigration cms-web_1 | up 20190129103831 2020-01-23 09:11:41 2020-01-23 09:11:41 AddLinuxDisplayProfileMigration cms-web_1 | up 20190212112534 2020-01-23 09:11:41 2020-01-23 09:11:41 AddProofOfPlayStatsDurationAndCountMigration cms-web_1 | up 20190212115432 2020-01-23 09:11:41 2020-01-23 09:11:41 AddDefaultTransitionDurationSettingMigration cms-web_1 | up 20190213160914 2020-01-23 09:11:41 2020-01-23 09:11:41 AddGlobalStatSettingMigration cms-web_1 | up 20190213162212 2020-01-23 09:11:41 2020-01-23 09:11:41 AddHorizontalMenuSettingMigration cms-web_1 | up 20190214102508 2020-01-23 09:11:41 2020-01-23 09:11:42 AddLayoutEnableStat cms-web_1 | up 20190214102516 2020-01-23 09:11:42 2020-01-23 09:11:43 AddMediaEnableStat cms-web_1 | up 20190220165703 2020-01-23 09:11:43 2020-01-23 09:11:44 AddScheduleRecurrenceMonthlyRepeatsOnMigration cms-web_1 | up 20190227101705 2020-01-23 09:11:44 2020-01-23 09:11:44 MakeDisplayLicenseColumnUniqueMigration cms-web_1 | up 20190228120603 2020-01-23 09:11:44 2020-01-23 09:11:45 AddDynamicCriteriaTagsMigration cms-web_1 | up 20190301115046 2020-01-23 09:11:45 2020-01-23 09:11:45 AdjustGenericfileValidExtensionsMigration cms-web_1 | up 20190315134628 2020-01-23 09:11:45 2020-01-23 09:11:46 AddBandwidthLimitColumnToDisplaygroupMigration cms-web_1 | up 20190322162052 2020-01-23 09:11:46 2020-01-23 09:11:47 AddPublishedDateColumnMigration cms-web_1 | up 20190326163016 2020-01-23 09:11:47 2020-01-23 09:11:47 CreateLayoutHistoryTableMigration cms-web_1 | up 20190328111718 2020-01-23 09:11:47 2020-01-23 09:11:47 AddCampaignStatMigration cms-web_1 | up 20190401150256 2020-01-23 09:11:48 2020-01-23 09:11:48 AddScheduleNowPageMigration cms-web_1 | up 20190509101525 2020-01-23 09:11:48 2020-01-23 09:11:48 CreateReportScheduleTableMigration cms-web_1 | up 20190509102648 2020-01-23 09:11:48 2020-01-23 09:11:49 CreateSavedReportTableMigration cms-web_1 | up 20190509113001 2020-01-23 09:11:49 2020-01-23 09:11:49 AddReportPageMigration cms-web_1 | up 20190510140126 2020-01-23 09:11:49 2020-01-23 09:11:51 TwoFactorAuthMigration cms-web_1 | up 20190514134430 2020-01-23 09:11:51 2020-01-23 09:11:53 NullableTextFieldsMigration cms-web_1 | up 20190515094133 2020-01-23 09:11:54 2020-01-23 09:11:54 AddHtmlDatatypeMigration cms-web_1 | up 20190515105624 2020-01-23 09:11:54 2020-01-23 09:11:54 InstallAdditionalStandardModulesMigration cms-web_1 | up 20190517080033 2020-01-23 09:11:54 2020-01-23 09:11:56 AddForeignKeysToLktagTablesMigration cms-db_1 | 2020-01-23 09:35:43 1 [Note] IPv6 is available. cms-db_1 | 2020-01-23 09:35:43 1 [Note] - '::' resolves to '::'; cms-db_1 | 2020-01-23 09:35:43 1 [Note] Server socket created on IP: '::'. cms-db_1 | 2020-01-23 09:35:43 1 [Warning] Insecure configuration for --pid-file: Location '/var/run/mysqld' in the path is accessible to all OS users. Consider choosing a different directory. cms-db_1 | 2020-01-23 09:35:43 1 [Warning] 'proxies_priv' entry '@ root@eb9b3b92f6f5' ignored in --skip-name-resolve mode. cms-db_1 | 2020-01-23 09:35:43 1 [Note] Event Scheduler: Loaded 0 events cms-db_1 | 2020-01-23 09:35:43 1 [Note] mysqld: ready for connections. cms-db_1 | Version: '5.6.47' socket: '/var/run/mysqld/mysqld.sock' port: 3306 MySQL Community Server (GPL) cms-db_1 | 2020-01-23 09:36:44 1 [Note] mysqld: Normal shutdown cms-db_1 | cms-db_1 | 2020-01-23 09:36:44 1 [Note] Giving 0 client threads a chance to die gracefully cms-db_1 | 2020-01-23 09:36:44 1 [Note] Event Scheduler: Purging the queue. 0 events cms-web_1 | up 20190521092700 2020-01-23 09:11:56 2020-01-23 09:11:56 AddReportScheduleTaskMigration cms-web_1 | up 20190521092930 2020-01-23 09:11:56 2020-01-23 09:11:57 AddPreviousRunDateReportScheduleMigration cms-db_1 | 2020-01-23 09:36:44 1 [Note] Shutting down slave threads cms-web_1 | up 20190521102635 2020-01-23 09:11:57 2020-01-23 09:11:58 PlaylistDurationUpdateAtTimestamp cms-db_1 | 2020-01-23 09:36:44 1 [Note] Forcefully disconnecting 0 remaining clients cms-web_1 | up 20190603083836 2020-01-23 09:11:58 2020-01-23 09:11:59 ChangeStatTableStartEndColumnMigration cms-db_1 | 2020-01-23 09:36:44 1 [Note] Binlog end cms-db_1 | 2020-01-23 09:36:44 1 [Note] Shutting down plugin 'partition' cms-db_1 | 2020-01-23 09:36:44 1 [Note] Shutting down plugin 'PERFORMANCE_SCHEMA' cms-web_1 | up 20190610150331 2020-01-23 09:15:05 2020-01-23 09:15:06 TagsWithValuesMigration cms-db_1 | 2020-01-23 09:36:44 1 [Note] Shutting down plugin 'INNODB_SYS_DATAFILES' cms-web_1 | up 20190611145607 2020-01-23 09:15:06 2020-01-23 09:15:06 RemoveOldVersionTableMigration cms-db_1 | 2020-01-23 09:36:44 1 [Note] Shutting down plugin 'INNODB_SYS_TABLESPACES' cms-web_1 | up 20190612140955 2020-01-23 09:15:06 2020-01-23 09:15:10 DisplayTableDatabaseSchemaAdjustmentsMigration cms-db_1 | 2020-01-23 09:36:44 1 [Note] Shutting down plugin 'INNODB_SYS_FOREIGN_COLS' cms-web_1 | up 20190620112611 2020-01-23 09:15:10 2020-01-23 09:15:11 MoveTidyStatsToStatsArchiveTaskMigration cms-db_1 | 2020-01-23 09:36:44 1 [Note] Shutting down plugin 'INNODB_SYS_FOREIGN' cms-web_1 | up 20190620142655 2020-01-23 09:15:11 2020-01-23 09:15:12 AddPlaylistEnableStatMigration cms-web_1 | up 20190626091331 2020-01-23 09:15:12 2020-01-23 09:15:13 WidgetHistoryMigration cms-db_1 | 2020-01-23 09:36:44 1 [Note] Shutting down plugin 'INNODB_SYS_FIELDS' cms-db_1 | 2020-01-23 09:36:44 1 [Note] Shutting down plugin 'INNODB_SYS_COLUMNS' cms-db_1 | 2020-01-23 09:36:44 1 [Note] Shutting down plugin 'INNODB_SYS_INDEXES' cms-db_1 | 2020-01-23 09:36:44 1 [Note] Shutting down plugin 'INNODB_SYS_TABLESTATS' cms-db_1 | 2020-01-23 09:36:44 1 [Note] Shutting down plugin 'INNODB_SYS_TABLES' cms-db_1 | 2020-01-23 09:36:44 1 [Note] Shutting down plugin 'INNODB_FT_INDEX_TABLE' cms-db_1 | 2020-01-23 09:36:44 1 [Note] Shutting down plugin 'INNODB_FT_INDEX_CACHE' cms-db_1 | 2020-01-23 09:36:44 1 [Note] Shutting down plugin 'INNODB_FT_CONFIG' cms-db_1 | 2020-01-23 09:36:44 1 [Note] Shutting down plugin 'INNODB_FT_BEING_DELETED' cms-db_1 | 2020-01-23 09:36:44 1 [Note] Shutting down plugin 'INNODB_FT_DELETED' cms-web_1 | up 20190626110359 2020-01-23 09:15:13 2020-01-23 09:15:16 CreateStatTableMigration cms-db_1 | 2020-01-23 09:36:44 1 [Note] Shutting down plugin 'INNODB_FT_DEFAULT_STOPWORD' cms-web_1 | up 20190628083649 2020-01-23 09:15:16 2020-01-23 09:15:16 AddStatsMigrationTaskMigration cms-web_1 | up 20190710213414 2020-01-23 09:15:16 2020-01-23 09:15:21 AddIsActiveReportScheduleMigration cms-web_1 | up 20190717101342 2020-01-23 09:15:21 2020-01-23 09:15:21 NullableCommandValidationStringMigration cms-web_1 | up 20190719074601 2020-01-23 09:15:22 2020-01-23 09:15:22 MissingDefaultValueMigration cms-web_1 | up 20190801102042 2020-01-23 09:15:22 2020-01-23 09:15:22 DisplayProfileCommandLinkFixMigration cms-web_1 | cms-web_1 | Importing ca-certs cms-db_1 | 2020-01-23 09:36:44 1 [Note] Shutting down plugin 'INNODB_METRICS' cms-web_1 | cp: can't stat '/var/www/cms/ca-certs/*.pem': No such file or directory cms-db_1 | 2020-01-23 09:36:44 1 [Note] Shutting down plugin 'INNODB_BUFFER_POOL_STATS' cms-web_1 | cp: can't stat '/var/www/cms/ca-certs/*.crt': No such file or directory cms-db_1 | 2020-01-23 09:36:44 1 [Note] Shutting down plugin 'INNODB_BUFFER_PAGE_LRU' cms-db_1 | 2020-01-23 09:36:44 1 [Note] Shutting down plugin 'INNODB_BUFFER_PAGE' cms-db_1 | 2020-01-23 09:36:44 1 [Note] Shutting down plugin 'INNODB_CMP_PER_INDEX_RESET' cms-db_1 | 2020-01-23 09:36:44 1 [Note] Shutting down plugin 'INNODB_CMP_PER_INDEX' cms-db_1 | 2020-01-23 09:36:44 1 [Note] Shutting down plugin 'INNODB_CMPMEM_RESET' cms-db_1 | 2020-01-23 09:36:44 1 [Note] Shutting down plugin 'INNODB_CMPMEM' cms-db_1 | 2020-01-23 09:36:44 1 [Note] Shutting down plugin 'INNODB_CMP_RESET' cms-db_1 | 2020-01-23 09:36:44 1 [Note] Shutting down plugin 'INNODB_CMP' cms-db_1 | 2020-01-23 09:36:44 1 [Note] Shutting down plugin 'INNODB_LOCK_WAITS' cms-db_1 | 2020-01-23 09:36:44 1 [Note] Shutting down plugin 'INNODB_LOCKS' cms-db_1 | 2020-01-23 09:36:44 1 [Note] Shutting down plugin 'INNODB_TRX' cms-db_1 | 2020-01-23 09:36:44 1 [Note] Shutting down plugin 'InnoDB' cms-db_1 | 2020-01-23 09:36:44 1 [Note] InnoDB: FTS optimize thread exiting. cms-db_1 | 2020-01-23 09:36:44 1 [Note] InnoDB: Starting shutdown... cms-db_1 | 2020-01-23 09:36:46 1 [Note] InnoDB: Shutdown completed; log sequence number 3986800 cms-db_1 | 2020-01-23 09:36:46 1 [Note] Shutting down plugin 'BLACKHOLE' cms-db_1 | 2020-01-23 09:36:46 1 [Note] Shutting down plugin 'ARCHIVE' cms-db_1 | 2020-01-23 09:36:46 1 [Note] Shutting down plugin 'MRG_MYISAM' cms-db_1 | 2020-01-23 09:36:46 1 [Note] Shutting down plugin 'MyISAM' cms-db_1 | 2020-01-23 09:36:46 1 [Note] Shutting down plugin 'MEMORY' cms-db_1 | 2020-01-23 09:36:46 1 [Note] Shutting down plugin 'CSV' cms-db_1 | 2020-01-23 09:36:46 1 [Note] Shutting down plugin 'sha256_password' cms-db_1 | 2020-01-23 09:36:46 1 [Note] Shutting down plugin 'mysql_old_password' cms-db_1 | 2020-01-23 09:36:46 1 [Note] Shutting down plugin 'mysql_native_password' cms-db_1 | 2020-01-23 09:36:46 1 [Note] Shutting down plugin 'binlog' cms-db_1 | 2020-01-23 09:36:46 1 [Note] mysqld: Shutdown complete cms-db_1 | cms-db_1 | 2020-01-23 10:25:17+00:00 [Note] [Entrypoint]: Entrypoint script for MySQL Server 5.6.47-1debian9 started. cms-db_1 | 2020-01-23 10:25:23+00:00 [Note] [Entrypoint]: Switching to dedicated user 'mysql' cms-db_1 | 2020-01-23 10:25:23+00:00 [Note] [Entrypoint]: Entrypoint script for MySQL Server 5.6.47-1debian9 started. cms-db_1 | 2020-01-23 10:25:24 0 [Warning] TIMESTAMP with implicit DEFAULT value is deprecated. Please use --explicit_defaults_for_timestamp server option (see documentation for more details). cms-db_1 | 2020-01-23 10:25:24 0 [Note] mysqld (mysqld 5.6.47) starting as process 1 ... cms-db_1 | 2020-01-23 10:25:24 1 [Note] Plugin 'FEDERATED' is disabled. cms-db_1 | 2020-01-23 10:25:24 1 [Note] InnoDB: Using atomics to ref count buffer pool pages cms-db_1 | 2020-01-23 10:25:24 1 [Note] InnoDB: The InnoDB memory heap is disabled cms-db_1 | 2020-01-23 10:25:24 1 [Note] InnoDB: Mutexes and rw_locks use GCC atomic builtins cms-db_1 | 2020-01-23 10:25:24 1 [Note] InnoDB: Memory barrier is not used cms-db_1 | 2020-01-23 10:25:24 1 [Note] InnoDB: Compressed tables use zlib 1.2.11 cms-db_1 | 2020-01-23 10:25:24 1 [Note] InnoDB: Using Linux native AIO cms-db_1 | 2020-01-23 10:25:24 1 [Note] InnoDB: Not using CPU crc32 instructions cms-db_1 | 2020-01-23 10:25:24 1 [Note] InnoDB: Initializing buffer pool, size = 128.0M cms-db_1 | 2020-01-23 10:25:24 1 [Note] InnoDB: Completed initialization of buffer pool cms-db_1 | 2020-01-23 10:25:25 1 [Note] InnoDB: Highest supported file format is Barracuda. cms-db_1 | 2020-01-23 10:25:28 1 [Note] InnoDB: 128 rollback segment(s) are active. cms-db_1 | 2020-01-23 10:25:28 1 [Note] InnoDB: Waiting for purge to start cms-db_1 | 2020-01-23 10:25:28 1 [Note] InnoDB: 5.6.47 started; log sequence number 3986800 cms-db_1 | 2020-01-23 10:25:29 1 [Note] RSA private key file not found: /var/lib/mysql//private_key.pem. Some authentication plugins will not work. cms-db_1 | 2020-01-23 10:25:29 1 [Note] RSA public key file not found: /var/lib/mysql//public_key.pem. Some authentication plugins will not work. cms-db_1 | 2020-01-23 10:25:29 1 [Note] Server hostname (bind-address): '*'; port: 3306 cms-db_1 | 2020-01-23 10:25:29 1 [Note] IPv6 is available. cms-db_1 | 2020-01-23 10:25:29 1 [Note] - '::' resolves to '::'; cms-db_1 | 2020-01-23 10:25:29 1 [Note] Server socket created on IP: '::'. cms-db_1 | 2020-01-23 10:25:29 1 [Warning] Insecure configuration for --pid-file: Location '/var/run/mysqld' in the path is accessible to all OS users. Consider choosing a different directory. cms-db_1 | 2020-01-23 10:25:29 1 [Warning] 'proxies_priv' entry '@ root@eb9b3b92f6f5' ignored in --skip-name-resolve mode. cms-db_1 | 2020-01-23 10:25:30 1 [Note] Event Scheduler: Loaded 0 events cms-db_1 | 2020-01-23 10:25:30 1 [Note] mysqld: ready for connections. cms-db_1 | Version: '5.6.47' socket: '/var/run/mysqld/mysqld.sock' port: 3306 MySQL Community Server (GPL)
This text will be hidden
what should i do then sir?
need guidance
@alex
thaks of the attention guys, just found the solution
becareful when you chmod the repository
make sure in document root
