Addressing some bugs i've encountered
Hello, just wanted to adress some bugs i’ve encountered in Xibo CMS 2.0.3.
  • Can’t set image widget’s image from library, can only bet set from local storage.
  • Some name conflicts can occur with images when using the replace image button, which will then interfere when trying to upload an image with the name of either the replaced image’s name or the replacers name.
  • Remote DataSets in general have been janky, can’t confirm these though as the setup could have been wrong on my part, but in general, changes to the Remote DataSet after it’s been set and is used on a layout would not go through. This has been the case with truncation and changes to a column’s json data path.
Thought it might be worth mentioning.
Regards,
Frank
The Xibo Community site uses cookies. What are cookies?
