Added layout won't be visible at monitors
Hi, i add 2 Monitors to one pc, add them to displays and displaygroups. i add a layout, (a simple one for testing) and connect them with the displaygroup. then i add them to the schedule tab and add them to run all day. So i think thats all i have to do. But my 2 monitors show only the “xibo open source digital signage” default view.
Could someone give me a hint to view my layout?
regards sebastian
Could you show us a screenshot of status window on your device please?
Hi, i don’t know what you extaly mean, status of my pc or in my xibo-display-view?
Oh, i got it. i don’t know that i have to setup the xibo client for every user. once i installed xibo i use ot with my user, but the pc should run with an other one…
now its working. thanks.
That could be the problem yes, by default Xibo player is added to the windows user account on which you’ve installed it, but if it needs to run on a different user, then you may need to make some adjustments.
Just for the future reference, when I mentioned the player status windows, I meant the window you can open by pressing i on your keyboard while Xibo for Windows has focus.
