Add "revised" column to Layouts
Is It possible to add a “revised” column to Layouts similar to the option in the Media Library?
Library: Media
Here are the only available column options in “Layouts”
What do you think that column would mean exactly?
The end user wants to sort the layouts by order of “last modified” so they know what is current. Does that make sense? They basically want to see the time/date that an item was last edited.
Ah OK i see - in 1.8.7 we have a modified column which should help you. I can’t recall exactly when that was added - maybe 1.8.5
Yeah, that will help. We’re still on 1.8.2 We’ll get the server upgraded. Thanks!
