Sorry I am not clear what the issue is here?
As shown in the screenshot, two explanatory labels for what you’re doing conflict:
One says the assignment is not automatically maintained, and the other, talking about the same thing, near as I can tell, says it is automatically maintained.
[ A screenshot I saw elsewhere suggests maybe it is automatic, and the labelling was fixed in 3.3.2? ]
Its obvious now that you’ve explained it, thank you.
Issue here:
“changes when Dynamic is selected”… presumably, somewhere else in the workflow? Not on that tab, right?
Indeed, on the first tab where you pick whether you’re creating a dynamic playlist or not. In the longer term we could make this two distinct options?
- Create Playlist
- Create Dynamic Playlist
My inclination is to say that the first tab should only say whether it’s Dynamic, and whether it’s dynamic should just be a factor of whether there are any defined filter lines on the second tab or not; no separate checkbox.
Is there a use-case for having filters defined but not being dynamic?
If so, leave it a manual checkbox, but move it to the Filter tab.
We will make it clearer somehow.
You can prepopulate the list on creation
