Add Event with DayParting Always
I created an event with Daypart Always. It is not visible in the calendar view month. Only in the agenda view.
I’m too stupid to delete that (ID 1 and ID 4)
If this is on Windows or a 32 bit Linux distribution, then it’s the following bug:
Windows Server 2008 64 Bit
Apache 2.4.23
MariaDB 10.1.19
PHP 5.6.28 (VC11 X86 32bit thread safe) + PEAR
Yeah - Windows PHP has a 32 bit limit on integers, regardless of whether or not the OS is 64 bit. So it is that bug.
You can make the patch to lib/Entity/Schedule.php from here:
And then run the SQL given:
UPDATE `schedule` SET toDt = 2147483647 WHERE toDt = 2556057600;
to resolve if you wish.
Thank you very much. Now it works. Are now on the calendar.
