404 script errors and schedule.view is not available after 3.0.0 upgrade and migration
Installation Method
Custom install
Operating System
Linux
upgraded like everytime. But from 2.3.7 to 3.0.0 there are 404 errors. And the “schedule.view” is not available. Maybe the 404 errors are from a wrong path in the html…
because “webdist” should be “web/dist”
Provide screenshots where possible!
Hi, thank you for reporting this issue.
We have recreated the problem with schedule.view and will get a fix deployed for that. You other issue is more difficult to solve, but we will try to recreate it now.
It is unusual to have web/ in your URL and this usually points to an installation issue because the CMS is designed since 1.8 so that only the web/ folder is accessible to the internet.
That being said, Xibo should function when installed in a folder, so we will look at it.
Thanks!
Hi! Great tipp :slight_smile: solved the web/ problem, pointing the domain directly to the web folder :slight_smile:
