HI,
After pressing “Publish layout” a pop-up appears, “Are you sure you want to publish this Layout? If it is already in use the update will automatically get pushed.”
Only in the translated version, there are 3 button at the bottom [Cancel] [Cancel] [Publish] instead of the usual 2 : [Cancel] [Publish]
It is not in the en-GB version, I have seen it in Dutch and German.
Regards,
Jules
