CMS VERSION:
3.1.2 and previous
Hi Guys!
I noticed that when whe drag and drop a content in “Playlist Mode” on the Layout Editor makes the content be duplicated… take a look:
This seems to be happening when content is dragged into an area of the screent where there is some region on the back layer.
it appears to be dragging and dropping the content both in the Timeline of the Plailyst mode and in the region of the layer behind
Can you recreate this behavior out there?
Hi, I have recreated this issue and have passed onto the dev team to take a closer look!
I will update here…
Thank you for posting
Update
The following issue has been created:
opened 08:19AM - 30 May 22 UTC
bug
When dragging and dropping an element to the Playlist, if there's a region in th… e Viewer in the same position, it will add two Media/Widgets, we need to prevent the drop to the under the overlay element.
Thank your for bringing this to our attention.
Thank you for the support!
system
Closed
August 30, 2022, 9:35pm
5
