We are pleased to announce our first release candidate for the 2.2 version of Xibo. The codename for this version is “Olbers”.
This is a companion discussion topic for the original entry at https://blog.xibo.org.uk/2-2-0-rc1-released/
Hello Dan,
I added some french translations and improved some others but they don’t appear int his version. Also I want to translate the new strings to french but I can’t find them in LaunchPad (https://translations.launchpad.net/xibo).
Aren’t you using the translations anymore ?
Thank you.
Thank you for your post, we only build translations for stable releases as we feel it would be unfair to have people make translations that would most likely change.
Hi Natasha,
Thanks for your reply. I understand for this candidate release but even for the 2.1.1 stable, I couldn’t find the string Forgotten your password? at the login screen in LaunchPad.
I have translated some few things to french in the past that were implemented in Xibo but on these last versions, I noticed the translations aren’t imported any more.
Can you please tell me, for example, how to translate the Forgotten your password? string ?
Thank you.
Oh, I found it !
But it’s not in the GitHub series as recommended,
It’s in the 1.8 series !!!
Can you please tell then if I should continue the translation for the 2.x.x series using the GitHub series as recommended or should I keep using the old 1.8 series (because what I’ve done lately is in the GitHub series) ?
Thanks again.
Thank you for bringing this to our attention, there was indeed an issue which has now been rectified. You should now see the string ‘Forgotten Password’ in 2.0, 2.1, 2.2 series.
Going forward please do select a series to translate (ideally the latest one).
Thank you for taking the time to provide translations and improvements
