1.8-rc1 - Dataset Column Order Resets
Bug report:
When using a Dataset View Module in a layout, the custom column order is reset each time you ‘edit’ the Dataset View.
E.g. if you have edited the order of columns by dragging and dropping, the next time you edit this widget, it will reset the order.
Justin
Right, I was able to recreate this issue on our CMS Instance as well.
I’ve created a bug report for it, which you can see here:
https://github.com/xibosignage/xibo/issues/934
