When trying to use the Scheduler to schedule Forecast.io the Displays fail to download the widget:
We did try the verify all link.
Log:
15729 1405e56 2016-02-07 21:27 XMDS POST ERROR Bako-BigCountry-03 GetResource Request failed for dataSet id=4. Widget=203. Due to Not Found
15728 1405e56 2016-02-07 21:27 XMDS POST NOTICE Bako-BigCountry-03 GetResource Matched column: bgImagePath|10
15727 1405e56 2016-02-07 21:27 XMDS POST NOTICE Bako-BigCountry-03 GetResource Then template for each row is: <p><img src="[bgImagePath|10]" style="width: 100%;" /></p>
15726 1405e56 2016-02-07 21:27 XMDS POST DEBUG GetResource Manage links to Display Group
15725 1405e56 2016-02-07 21:27 XMDS POST DEBUG GetResource Updating Display Group. Bako-BigCountry-03, 2
UPDATE: I should have noted that the layout has been imported from an export on 1.7.3
UPDATE 2: When trying to just create a basic layout with just the default region, only Forecasti.io set to run, and assigning it as the default layout we get this:
17080 2016-02-07 21:40 Unable to reach Forecast API: Client error: `GET https://api.forecast.io/forecast/<FORCAST.IO API KEY>/,?units=auto&lang=en&exclude=flags%2Cminutely%2Chourly` resulted in a `400 Bad Request` response: <html> <head><
We double checked our Forecast.io API key, even changed it just in case. And we do see the weather in the layout builder, and preview of the new layout we created. (The old, imported layout fails to function, so I think, if I remember right that part just has not been completed yet.) So we are not sure why the 400 bad request. Even double checked my cacert.pem. And we have not hit the daily limit.
