1.8 Alpha 3 - Replace Media via CMS Syntax Error
Got this when trying to replace media in the CMS:
Log:
56223	2a36afa	2016-05-21 21:41	WEB	POST	DEBUG		/library	Loading Media. Options = {"deleting":true,"fullInfo":false}
56222	2a36afa	2016-05-21 21:41	WEB	POST	DEBUG		/library	Checking permissions against the logged in user: ID: 1, Name: root, UserType: 1
56221	2a36afa	2016-05-21 21:41	WEB	POST	DEBUG		/library	Checking permissions against the logged in user: ID: 1, Name: root, UserType: 1
56220	2a36afa	2016-05-21 21:41	WEB	POST	DEBUG		/library	Updating layouts with the old media 17 as the background image.
56219	2a36afa	2016-05-21 21:41	WEB	POST	DEBUG		/library	Checking permissions against the logged in user: ID: 1, Name: root, UserType: 1
56218	2a36afa	2016-05-21 21:41	WEB	POST	DEBUG		/library	Replace in all Layouts selected. Getting associated widgets
56217	2a36afa	2016-05-21 21:41	WEB	POST	DEBUG		/library	Copying permissions to new media
56216	2a36afa	2016-05-21 21:41	WEB	POST	DEBUG		/library	saveFile for "1_wali_1080_android_background.png" with storedAs = "", fileName = "Wali_Logo_Vert_1920x1080x300dpi_Black_BG.png" to "57.png"
56215	2a36afa	2016-05-21 21:41	WEB	POST	DEBUG		/library	Checking permissions against the logged in user: ID: 1, Name: root, UserType: 1
56214	2a36afa	2016-05-21 21:41	WEB	POST	DEBUG		/library	Replacing old with new - updateInLayouts = 1, deleteOldRevisions = 1
56213	2a36afa	2016-05-21 21:41	WEB	POST	DEBUG		/library	No pre-processing rules for this module type
56212	2a36afa	2016-05-21 21:41	WEB	POST	DEBUG		/library	Module Type = image
56211	2a36afa	2016-05-21 21:41	WEB	POST	DEBUG		/library	Upload complete for name: Wali_Logo_Vert_1920x1080x300dpi_Black_BG.png. Index is 0.
56210	2a36afa	2016-05-21 21:41	WEB	POST	DEBUG		/library	Hand off to Upload Handler with options: {"userId":1,"controller":{},"oldMediaId":17,"widgetId":null,"updateInLayouts":1,"deleteOldRevisions":1,"playlistId":null,"upload_dir":"C:\\xibo_library\\temp\/","download_via_php":true,"script_url":"\/xibo18alpha\/web\/library","upload_url":"\/xibo18alpha\/web\/library","image_versions":[],"accept_file_types":"\/\\.jpg|jpeg|png|bmp|gif$\/i"}
56209	2a36afa	2016-05-21 21:41	WEB	POST	DEBUG		/library	Checking permissions against the logged in user: ID: 1, Name: root, UserType: 1
56208	2a36afa	2016-05-21 21:41	WEB	POST	DEBUG		/library	New Player Action Service from DI
56207	2a36afa	2016-05-21 21:41	WEB	POST	DEBUG		/library	Loading 1. All Objects = 0
Seems to be fine on our current develop CMS, perhaps Dan will be able to tell you what could be wrong in your case.
I do remember fixing it during a recent piece of work, which will have been merged into develop.
If you can get the output of the request from developer tools (Network tab) then it might be something simple you could patch in.
Sounds Good. Thank you guys.
