Hi guys,
I’ve a problem with new task, I see the process list but don’t run. Even if I try to run them immediately, as you see in the screenshot below:
Thanks in advance.
Thomas
Hi guys,
Thanks in advance.
Thomas
Have you created a cronjob for it?
mmmm…no!
I’m not a linux expert, how can I do?
Thanx
I create a cronjob (* * * * * /usr/bin/php /var/www/html/spot.farma3tec.com/bin/xtr.php) but still the process list dont’t run.
I put cms in debug mode but I havent’ any kin of errors or alert.
I add that the maintenance script that is launched directly from the /maint page don’t work either.
The page is loaded for a long time and then returns an unknown error…
Try running is 4 or 5 times. Sometimes the build up of stuff to do is more than it can do before the script times out.
Wow now it’s ok, thanks!
Your welcome. Glad that worked.
