1.8.0 RC2 Player dont edit
After create a player i cant edit it, i receive data missing advice.
How have you created the player please?
Hello dan I created the player by installing the player 1.8.0rc2 win 32 in a notebook with win7 pro 32 and registering the same to the server. On the server it was not possible to edit the settings and the reported error appeared.
Regards
Pedro.
Obter o Outlook para Androidhttps://aka.ms/ghei36
Hi Dan
Today I made a new server and a fresh player and I discovered that the problem occurs after editing the options of the display settings windows type. I change collect intervall value to 1 minute and save, after that i cant edit player anymore.
Regards
Pedro.
I had the same issue. What fixed it for me was to change “Download Window Start Time” and “Download Window End Time” to something other than 00:00. After saving, I was able to change it back to 00:00.
Interesting - @peter can we try this out please and see if we can work out whats happening?
Same occurring here: Display menu, can not change settings
It’s seems it’s a bug on fresh 1.8.0-rc2 - Time picker in display profiles writes 0 instead of 00:00 to the hidden field which breaks Display edit form · Issue #994 · xibosignage/xibo · GitHub
That would be correct work around until it’s fixed.
On android profile you’d need to do the same with update window start/end time.
